  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly.. the car of course... The lil nagging problem I had wif the HICAS light and the rattling noises is become all too frequent and its damn annoying..
Just got a call from my mechanic, he's organising a data stream to see what exactly is wrong..  HICAS sensors apparently is not covered under my warranty.. but ABS is ... grrr.. not happy at all..
Hrmm.. guess the bright side is that a friend of mine is going to help me get some insulation into the doors and also fix the creaking that I have had on the passenger door for a while.
Whats wrong with your car dude? :D
Nexus.. I heard something about his wife taking over 75% of everything he owns and the shop was shut ?  I might have got it all wrong... thats why I wanted to see if you guys/grls know anything about it. :)
I THINK THAT MY PERSONAL LIFE HAS NOTHING TO DO WITH YOU OK
THE INFO YOU HAVE HEARD IS BULLSHIT.
SO SHUT YOUR MOUTH PLEASE - OR MY SOLICITOR MIGHT DO IT FOR YOU.
Yeah...  She may just come in here and set the story straight :headspin:
NO I WILL THANKYOU
GAVIN WOOD AUTO TECH IS NOT CLOSING DOWN AND NEVER WILL OK
I AM BUILDING THE BUSINESS TO GIVE TO MY 2 BOYS WHEN THEY GROW UP
THEY ARE ALREADY FOLLOWING DADS FOOTSTEPS WITH REGARD TO
MOTOR RACING
IF ANYONE HAS ANY QUERIES OR DOUBTS - PLEASE DONT HESITATE
TO CONTACT ME ON 0417760278
I WILL BE MORE THAN HAPPY TO SET THE STORY STRAIGHT
IT SEEMS TO ME THAT A LOT OF PEOPLE ON THIS SITE HAVE NOTHING BETTER
TO DO THAN BAG SOMEONE ELSES LIFE - THAT TO ME IS VERY SAD
GET A LIFE PEOPLE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GAVIN WOOD.
Not at work, the time over on the island was awesome, had a great time, but too much exercise for me, did more exercise in the last 3 days than I have in the last 3 years, so still a bit stiff and sore, got a raging head cold which is why I decided to call in sick :D
i think somebody wanted to set some rumours straight.. fair enough i guess..
Please PM WTF that was all about plz?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
