  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Good boi my ass, good mate with an understanding Moderator who'll pull you out of the poo more like it...
Awww... come on Squizz I'm already in the poo apparently.. but hey... I was asking one thing but had too much information into it... Realise my mistake in providing too much info at the time, which is something I will not do again.. :)
And and and I am a good boi :D
he could buy mine.. mine better :) more bang for buck
i hear smooth lives on his own Special Island.. going by the name of HomoT Island.. right next to Hope Island actually..
He aint buying yours! Mine was faster last time we were on the freeway anyway, WITH a slipping clutch :D hahahaha
Yes, HomoT island, where the real men run free.... :headspin:
He aint buying yours! Mine was faster last time we were on the freeway anyway, WITH a slipping clutch  hahahaha
that was before it got its mojo back.. its a fair amount faster now than ever.. this is going to have to be settled on the drag strip :D which reminds me actually
fcuk I work with a bunch of tonkas. If I had something sharp I'd be stabbing myself right now. Someone just stood beside my desk until I went to http://www.hiddensongs.com why you ask?
Because if you are living in the fu(k*** dark ages and hadn't figured out either mp3's or that there are "hidden super secret songs" at the end of cd's you can go to this website and it will tell you what cd's have them. fcuk wow. I knew I got out of bed this morning for a reason. "Thanks a lot for that I was wondering why the last album tracks often run for 14 mins when the rest of the songs on the album only ran for 2-3 mins max. I never thought of fast fowarding to the end of the song. "
edit: what's that? why does your computer constantly crash and run like crap? Perhaps because you are so dumb that you open your spam and then open all the attachments contained within. Thus flooding your computer with spyware and viruses. Sure follow some random link someone has sent you to http://butteredtoast.com or perhaps http://bonsaikitten.com it can't ruin your computer now can it.
