  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey charly.. y is your name says Liz ?? Is there something that we/I dont know about? :D
I thought it would be funny. Turns out it wasn't. Now I'm so scarred from the incident that I can't bring myself to change it. Has anyone figured out where my avatar came from yet?
man my thing is seriously sucking the jooce though now.. i filled up $10 at yatala this morning and now its nearly empty :D
What's more important sex or cruising ? just need to decide If I can make it out tonight
now that is a stupid question!
