  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Sure is!! I was going to take a photo last night but it was too damned cold to even bother!! I got home and ran straight inside, stole the heater from the bathroom and sat in my room :cheers:
Also, I didn't get home till 8. So it was a fair bit colder than it was at 6 :S
Was the pipe what you wanted?
Haha, you did look a bit chilled.
Will be hoooking up the pipe tonight...
This work suits don't exactly keep you very warm. I had also just been standing in cold water washing the car so my jacket and skirt was a little damp :cheers:
The trials and tribulations of erins life. It's very exciting! I lost $4 in the carwash as well because I didn't have time to go in and whnge that it broke, so I just chucked another $4 in another one.
*sigh*
Hello every one.
It was damn cold in Ipswich at 6:50am, I had Jeans, long sleeve shirt, jumper, jacket and benie and was still freezing.
Hey Gordo, that was quick. Gives me hope for mine when I put it up for sale in a couple months. Now the search for a replacement begins!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
