hmmmm
always problems when chasing power in my experience
the amount of crap I had to put up with in the S13 to get it to 225rwkw you wouldn't want to hear.
And after I sold it the guy who bought it wrote it off after four weeks, I was so upset for some reason :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah they get pretty hot, im still 'testing' i guess. i might move them if its a problem. gav seemed to think it was ok tho so i think they'll stay that way. i've actually cleaned up the hoses a bit too - hidden them (if thats possible)
i see you're bidding for a powerfc.. watch those second hand ones! i got burt a little. the hc was rooted but he gave me back 200 for it. and the ecu is an older version rom and doesnt do data logging thus the tune method gav is using.
Yeah just an EOI at this time.
More than likely get a new one from Nengun for $1100 with hand controller.
If the guy goes as low as I want, we will see :D
T & T sounds sweet. i guess im ready! cept tyres but i'll just let mine down a bit.
Yeah I was so close to a thirteen last week, except for the bald tyres.
I borrowed Jay's tyre pressure guage and thought I had let them down to 25 PSI, when I went to the servo to fill them up one was on 33psi and the other was on 31psi, so his guage wasn't quite accurate lol
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
