  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
:thumbsup:
yeah.. i'd prefer to see it b4 i buy it.. but oh well.. if u wanna save money then thats how u gotta do it..
havent seen any great bargains locally... few reasonably priced r33.. but i kind of had one of them.
I no of one over priced R32 for sale :D
