  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
sif you've never thrashed it.  I heard that you were driving it around on its rims throwing sparks for 5hits and giggles.
BTW I'm back from lunch.  love me.
No quite, But we'll just say I did that, as thats a better story.
btw now that you back from lunch I'm loving you.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
