  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
check out the powerplay imoprts ad. It looks like it was done by a three year old.
And have you seen the prices ....holy shit
$1650.00 for a Power FC and $594.00 for the hand controller.
What a joke :)
And have you seen their prices ....holy shit
e.g $1650 for a Power FC and $594.00 for the Hand Controller
What a joke :)
You can get the same combo from Nengun for at least a thousand dollars less
