  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
of all the weak sauce ever made you would have to be the weakest.  By far.
Also that's not weak sauce it's the 7year old fish food you were going to give out as a trophy the other week.  Get your eyes checked.
Where was your car yesterday?  exactly.
At home, on my driveway. You can feel all it's wrath when it goes onto the dyno :)
There was never more then one bottle of weak sauce made, hence me saying I own the only one - thus making me not weak sauce.
