put some stickers on it too josh.  I'm sure some sucker 17yo will get his father to buy it for him.  And what is with that story about the kid and his father just showing up for a joyride in your skyline?
All my cars minus my Red r32 were payed by me... and the GTR I will get a loan off dad... so stop implying what I think you are.
It wasn’t my skyline they came to look at. It was one of my Silvia's. The kid showed up with his mates had his father (he went to my school) so I kind of knew who he was.
They all talked it up how they were full into imports - more so turbo silvia's ect, and that that loved our drag silvia blah blah blah. They tired kicked me so much I really did believe that his was keen.
Any who I took him a drive (read 180 limiter, then some mountain drifting) as the kid talked up how much he was gunna build up a Silvia drift car... blah blah blah endless phone calls from me asking what the deal is, weather he was still gunna buy it ect. He finally said he had no money. I still see him and his mates ride around on pushbikes as well!!! Damn bum is a trolley pusher at action supermarket as well.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Actually josh, I wasn't implying anything about you with that post of mine you quoted. It was more a comment on suxors buying cars that look good impulsively that are mechanically unsound. Also I cbf'd calling you a trust fund baby any more. Our lives are what they are. so meh. It was more to find out the story that you just posted because I'd never heard it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
