put some stickers on it too josh.  I'm sure some sucker 17yo will get his father to buy it for him.  And what is with that story about the kid and his father just showing up for a joyride in your skyline?
All my cars minus my Red r32 were payed by me... and the GTR I will get a loan off dad... so stop implying what I think you are.
It wasn’t my skyline they came to look at. It was one of my Silvia's. The kid showed up with his mates had his father (he went to my school) so I kind of knew who he was.
They all talked it up how they were full into imports - more so turbo silvia's ect, and that that loved our drag silvia blah blah blah. They tired kicked me so much I really did believe that his was keen.
Any who I took him a drive (read 180 limiter, then some mountain drifting) as the kid talked up how much he was gunna build up a Silvia drift car... blah blah blah endless phone calls from me asking what the deal is, weather he was still gunna buy it ect. He finally said he had no money. I still see him and his mates ride around on pushbikes as well!!! Damn bum is a trolley pusher at action supermarket as well.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Actually josh, I wasn't implying anything about you with that post of mine you quoted. It was more a comment on suxors buying cars that look good impulsively that are mechanically unsound. Also I cbf'd calling you a trust fund baby any more. Our lives are what they are. so meh. It was more to find out the story that you just posted because I'd never heard it.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
