i fitted another window motor and the auto up would take window up and then bring it back down 100mm and stop, now auto up is not working at all, my mazda does this every now and then with the window close opition on the alarm until the auto up stops working then i just have to hold the button up with window closed for 5 secs and it resets, i tryed this with the gtr when it stopped and it doesn't work, does anyone know how to reset then.
https://www.sau.com.au/forums/topic/343222-r34-gtr-window-auto-up/
I think it's either pushing the button down twice quickly or pulling the button up twice quickly. It happened to me last week.
might be a longshot but try holding it down till the window goes all the way down, then keep holding it down for a few seconds. Then go up until the window is all the way up and hold it there for a few seconds
My auto up down stopped working and I think thats what I did to fix it. But it could just be my car being strange, auto up down doesnt work anymore when the car gets hot (sitting in the sun for a while) but I think when i tried that fix the car wasnt hot
  • 1 year later...
I know this is an old thread but the provided solutions does not work for an r34 GTR.
There is a reset button on the motor itself.
The procedure requires the door card to be removed.
Where the 4 bolts that hold the motor to the door skin you will see one of the bolts with a letter on a small bracket - my case i was fixing the drivers window so the letter had an R stamped on it.
To the left of this bolt you will see a small hole cut out in the door about the size of a 20 cent piece - about 2 cms away. It looks like a little rubber grommet but is actually a reset switch on the back of the actual motor.
With the door closed and the ignition turned to on (engine not started) and the window in the fully up position (dont use the auto up here if the window wasnt fully up)
Hold the reset button (the rubber reset switch on the motor) while bringing the window all the way to the down position without using the auto down
Let go of reset switch
Try the auto up now - should work if not try the procedure again.
I tried the 5 second hold down and hold up option that other nissans use but this is what worked for me.
Hope this helps someone as this was doing my head in lol :)
  • Like 1
My R34 GT-T has done the down 10cm thing after using auto-up button randomly (maybe once every 30 uses) since I bought it.
For me, you can hear the window squeezing against the rubber seal at the top, and I always put it down to too much resistance on the seal causing it to think it hit something and go down.
I wouldn't mind hearing if there is a proper fix though. Might try what BarbsGTR suggested.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
