Parts are second hand and condition is noted.
Pick up prefered.
Items locted in Richmond.
Price is for pick up only, posted at buyers expense for smaller items only.
PM for info etc.
R34 GTR vspec rear sway bar in good condition
$80
R34GTR Front swaybar, not shown, good condition
$50
R34 GTR catback exhaust 80mm good condition
$200
R34GTR pedal lever assy set, with rubber pads (clutch, brake, and accelerator) In as new condition, pedal rubbers secondhand.
$100 Will get pic if requested
Cat converter with 80mm ends, good nick ran 288RWKW
$50
VL commodore live axle diff with 3.45:1 center, missing bearing caps and axles. Crown and pinion in good condition
$200
R32GTR rear bulkhead metal blank (sits behind rear seat)
$10
R32GTR front suspension upper camber arms, bushes still in good condition
$20 for the pair
R32GTR alternator, needs a new voltage reg/rebuild
$20
Apexi pod filters and intake adapters/brackets, good condition from 34GTR
$50
300ZX NA exceedy flywheel and clutch, plenty of meat, good condition needs a clean
$100
F*#¥€N Hell...
I always missout on your good sale items...
Next inline for the pods if it falls through please...
Let me know asap if this item is available again can pickup asap!!!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
