Danooh- I will certainly let you know and congratulations on your car...
I didn't hear any noises but it did misfire between 5K and 6K rpm's.  I picked up the car and it was completely out of fuel.  I filled it to the top with BP premium.  I drove it for a good 60km's before I had the problem.
how 'big' was the misfire? was it a hesitation/cough, or more of a backfire? check your fuel filter - could be as simple as a blockage.
was the car pulling hard before it happened? I haven't revved my car over 3000rpm (free rev) as I want to go right over it.
I bought it redline engine and gearbox oil the other day - so will be changing that before I actually take the car on the road. My car ran out of fuel on in my drive after we took it off the back of the truck - I will changing the fuel filter as well.
hopefully it is more of a minor thing with your car
damn another perthian, and even better, A CHICK!!!!
ummm if it was blue - your rings are well and truly buggered
if it was black - your running really really rich
if it doesnt want to start, then your probably gonna find either a piston's jammed and/or a conrod is jammed also
either way, your gonna be up for big bucks for some1 to look at it
Skyline Performance Imports haven't had a chance to look at it yet.
One other thing that I can recall is that when I turn the car over I noticed that the oil pressure light was on.
There was no backfiring it was just misfiring.
OK
It has been confirmed that the car requires a full engine rebuild (around $8K) :D
I was unknowingly driving the car on full boost (close to 30psi) which resulted in the damaging of the rings and pistons. A very very expensive lesson to have to learn...
One of the problems with buying a modified car... you don't know what the guy before you has done... Mmmm 2 bar boost... I don't think that even if you had changed it back to ~12-15 whatever standard GTR boost is that you could have saved that engine... the guy who sold it in japan obviously knew it was on the way out (which sucks for you) and i just hope the same won't happen to me when i get my 93 GTS-t.
welcome to the rebuild club! they took my engine out .... apparently i broke 5 pistons :D Hope you have a very generous bank manager ...... but its a lot of fun once you get it back .... go the forgies!!
Pilot boy .... never seen you around before! hello.
I reckon its probably because the car has been sitting for so long, take it for a bit of a drive clean it out, but dont rev too much just incase.
I hade the same problem once, my car been sitting for about 4 months, started to drive it and heaps of smoke came out, after about 1k it went away.
ben
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
