1995 Nissan Skyline GTS-T Coupe. Manual 6 cyl Turbo
2.5T 5 Speed Manual. Maroon.
152,868km.
work, parts and info for skyline r33 gtst
Nismo front grill, Hybrid front mount intercooler Custom 2.5in-3in intercooler piping, Stainless Blitz mesh 5in pod filter, 4in 90 deg alloy intake pipe filter to turbo, 40mm alloy radiator, Black silicone radiator hoses Carbing alloy radiator air deflector, 2x 12in thermo fans, Greddy Type R BOV 50mm, Garrett gt3540 ex gated with all speed flow fittings new and speed flow braided lines, HKS external gate 50mm, Custom intake plenum manifold ported and polished, New oil catch can, Splitfire coil packs, HKS Spark plugs, Turbosmart FPR, Ported and polished head, Tomei cams, Felpro SS valves, Tomei type b valve springs, Cometic multi layer metal head gasket, CP pistons/rings, Eagle conrods, ACL Race bearings, All gaskets are new on engine top to bottom, Jim Berry race clutch, 3 inch dump pipe with race cat, HKS hi power exhaust SS, EBC red stuff Brake Pads, Walbro hi flow Feul pump, Hicas rear steer lock bar, Work VR 10.5in rear 9in front light weight racing wheels wraped Federal 595 ss tyres 70 % tread, Tinted windows, Momo wheel, Greddy gear knob, Blitz turbo timer, Greddy profec b II boost controller, New VIPEC ecu, Pioneer head unit Pioneer splits front 6x9 pioneer rear 400w pioneer amp, Boost gauge and water temp gauges not fitted yet, All Dyno tuning By Mark @ Godzilla Motorsport. Currently still on run in tune 7PSI with 302rwhp, First part of run in was on dyno with mark bedding in rings with mineral oil dumped at end of 3 hour dyno tune and run with fresh mineral oil for another 1500km And run with HKS RB full synthetic oil Since approx 2-3000 km, has been meticulously looked after and serviced. Gear and diff oils changed 5000km ago.
plus more that have not remembered.
i Have reciepts for more than $20k spent
services every 5-10 k with only the best oils from Royal Purple, HKS and magnetic oil filters and sump plug for that little xtra protection.
A lot of TLC has gone into this project to make sure that it is a strong reliable but also powerful example.
i wont bullshit with numbers for expected kw/HP like some because i would hope it speaks for itself, but in saying that it was built to handle 25+ PSI Day in Day out .
ASKING $17,000 ONO
For More Information Please call Marcus on 0412622263
post-20616-1289212846_thumb.jpg post-20616-1289212876_thumb.jpg post-20616-1289212893_thumb.jpg post-20616-1289213142_thumb.jpg
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
