Item Summary: ARC coilovers, Prof Sheepdog BOV
Condition: Used
Reason for Selling: New Coilovers, Don't want BOV
Asking Price: 500
Delivery Methods: PickUp
Contact Info: 0423 424 834 or pm me
Extra Information:
Hey guys have a set of ARC coilovers made to suit r33/34GTR but also suit a GTT (what i have them in atm). They are very nice coilovers real comfortable ride while still improving the handling dramatically. Reason for me selling them is they are not base height adjustable and i would like this. Also the front left needs a rebuild (quoted $250 from TSR in Slacks creek) But otherwise in perfect nick.
I paid 600 for these so want to sell for $300 which is very good considering the full set in good nick will come to $550 after the rebuild.
Second is a JDM Prof Sheepdog BOV. This is attached to piping to suit a r34 gtt (maybe r32/33 not sure) but can be removed from this easily (would make installing on r34 very easy about a 20min job). I have never used this item but it appears to have had some use while still being in very good nick. These can be plumbed back or vent to atmosphere very nice sounding BOV.
Asking $150 for this
Coilover pricing is firm but am negotiable on the BOV.
Can get pics of the BOV if needed pic of coilovers attached
https://www.sau.com.au/forums/topic/343609-arc-coilovers-and-prof-sheepdog-bov/
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
