So after last decas dinner fail the organiser has called it quits for this one. So we are going elsewhere this time!
We are going to the GV Hotel
Only difference being its book your own table. i suggest getting people who are keen organise tables in the thread. I have already booked a table under SAU so ask to be put near that one :P
Dinner is booked for 830 but we will be getting there around 8 for a drink first.
Its unfortunate that Taco Bills ran its course already but with the new owners, new staff, new name it simply lost its original appeal. its fair to say the new owners dont quite get us :P Shouldnt change the second half of the night though!
Below are people who i have booked for. Im sure it will be more than one table.
Ryan
Bec
Mick
Joy
Tim
Christ +2
Lukey +2
Al C +6
Dan H
Bris
Tom G
Bigbird
Ask +1
Rosco +4
Newton +2
Anna
Harsh
Total 34
https://www.sau.com.au/forums/topic/343904-deca-dinner-saturday-night-the-gv/
I meant Shane as in Purple R33 GT-R Shane (Leon and Wayne's relative.) Would you like to be on the table too? Happy to ring them up and change the booking to 9x. Also, if anyone else wants in on this table let me know now.
you sure wont be partying alone Anna. I will add you and Harsh to the tables.
I am more than happy to add people to the booking on the simple condition that if you dont turn up by 830 we wont book anything for you again :D including hotels hehe.
The last thing i want to do is organise sat night as well but i sure wasnt going to do nothing and we want everyone to come along!! hence the simple rule :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
