  • Replies 55
These come with coated (Teflon) skirts, (Silent on startup, less wear on pistons)
Also these come with Ductile Iron Plasmamoly coated rings, (Alot stronger than normal Chomemoly rings, that most forged pistons come with)
If your in let me know, Im trying to organise it all for this week. And if you come into the deal final price for everyone is $1050.
Cheers,
Trev
Sorry dude, price isnt set by me. :D
Also, these pistons are fantastic. I can vouch for them personaly, & im sure Clint can aswell...
These arent your normal forged piston,
Wiseco garentee that all pistons tolerances are less than one-half-of-one-thousandths of and inch (.0005). Your normal forgies arent....
Aswell as Ductile Iron Plasmamoly coated rings, as apposed to normal Chromemolys that most forgies use.
Also, you wont get your piston skirts coated for free, and give it to you for $950 deliverd to your door. :P
If your still intrested, send me a email [email protected]
Cheers,
Trev
Also for all the people bitching in a email to me, about "price" ... (You know who you are)
SERIOUSLY.... If you think you can get a better quality piston for a better price, GO FOR IT!
Im sick to death reply to emails that say.
"My motor builder says that XXXX piston is better... BLAH BLAH BLAH"
I sell these pistons to over 13 Diffrent engine builders & Machinists (Many of which have Top fuelers) because they cant get this price "Trade". If i was your engine builder i would be saying these are crap too! i would love to make an extra 250 bucks out of you.
If your not intrested in buying a quality piston, at a dirt cheap price, thats ok by me. Im not doing any more "group buys, or forum sales" after this one. Because i dont need the extra stress for 3-4 buys, that i allmost loose money on. I respect the people that havent stuffed me around and have asked geniune questions & purchases.
Rant over,
Trev
  • 5 weeks later...
hmm ok
I was looking foward to getting one of these kits as they are much better quality then some of the other cheap ones around.
I have no problem with price, quality, etc i just need pistons.
Would you deal with my engine builder?
If you will or feel like helping me out please e-mail me back at [email protected]
Thanks
John
  • 4 weeks later...
il email you tonight,
Cheers,
Trev
Trev,
I saw that you'd had the jam sucked out of your donut by timewasteing tyre kickers (being polite). Fair enough, I know how you feel.
I, however, don't waste peoples time. I'm picking up an RB30 in a week. I will be rebuilding it with forgies, prepped rods (only want 300 at the wheels...). It is a sure thing.
Can you still get piston sets?
I can't tell you what size until I rip the engine down and measure the bores to see how much over I need to go to straighten them up again.
If yes, good. If no, any tips?
Thanks mate,
Adrian
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
