hey guys
i have been forced to sell my car as im moving away for work in western australia, it has to be gone by end of the year.
i bought the car in 2008 of a old lady was pretty much standard sr20 so ive built this car from ground up, the conversion is mod plated so it is legal. motor was built at gavin woods autotech on the gold coast, motor is still fresh.
i love this thing but i cant take it with me
the car won best late model award at stadium drift
featured in fast fours magazine this year
also featured at gold coast autosalon
r33 1997 gtr engine
Greddy 264deg easy cams
Greddy valve springs
hks cam gears
gates timing belt
Trust Metal Head Gasket
trust clear cam gear cover
Tomei oil restrictor
Arias Pistons
Eagle rods
Nismo bearings
billet oil pump
N1 Water Pump
Head fully recon'd and lifters set for the cams
Fully balanced
Block and crank crack tested
Block acid dipped, decked etc
Crank linished
garrett gt3582r
greddy high mount manifold
greddy external wastgate type r
greddy y intake pipe
hks pod filters
greddy Fuel Rail
hks fuel reg
Sard 700cc injectors
Tomei Sump Baffles
apexi power fc d-jetro
superspark coilpacks
custom rwd sump
4 inch dump
trust stainless 80mm cat back exhaust
cooling pro 600x300x100 intercooler
custom 3'' cooler piping
saber alloy radiator
twin 12 inch thermos
alloy polished overflow bottle
turbosmart e boost 2 (40psi)
turbosmart supersonic bov
whiteline sway bars front and back
whiteline strut brace
rear adjustable camber arms
rear adjustable toe arms
racing logic coilovers
rb25det gearbox
exedy button clutch
exedy lightweight flywheel
custom tailshaft
walbro fuel pump
saber guages oil press, oil temp, water temp and boost mounted in the air con vents
battery relocated to the boot
r34 gtr v spec front seats
retrimmed door cards in suede
smoked tailights
nismo smoked side indicators
blits fibreglass adr approved vent bonnet
vertex front bar
vertex rear bar
vertex side skirts
shaved boot lock
flared rear guards
resprayed in r34 gtr nur gold (millennium jade) with gold flake including engine bay
volk gts gunmetal grey 18x9+27 18x10+23
made 408rwhp on 15psi and 450rwhp on 18psi
serious offers only.
$31000ono
brad 0421511710 or pm
pm for pictures as its not working
https://www.sau.com.au/forums/topic/344357-fs-rb26-powered-s15-2001-rbs15/
Why cant you bring it with you?
Im pretty sure with the rules in WA if you have owned the car for more then year then when you move here you can just go and get WA numberplates for it and rego'd it here. So doesnt need to be inspected etc.
If this was licensed in WA would sell quick over for sure.
thanks for the comments also thinking of putting a standard motor in for anyone that has a lower budget
please dont do this....... keep it how it is... someone will buy it, i wish i had more cash
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
