hey guys
i have been forced to sell my car as im moving away for work in western australia, it has to be gone by end of the year.
i bought the car in 2008 of a old lady was pretty much standard sr20 so ive built this car from ground up, the conversion is mod plated so it is legal. motor was built at gavin woods autotech on the gold coast, motor is still fresh.
i love this thing but i cant take it with me
the car won best late model award at stadium drift
featured in fast fours magazine this year
also featured at gold coast autosalon
r33 1997 gtr engine
Greddy 264deg easy cams
Greddy valve springs
hks cam gears
gates timing belt
Trust Metal Head Gasket
trust clear cam gear cover
Tomei oil restrictor
Arias Pistons
Eagle rods
Nismo bearings
billet oil pump
N1 Water Pump
Head fully recon'd and lifters set for the cams
Fully balanced
Block and crank crack tested
Block acid dipped, decked etc
Crank linished
garrett gt3582r
greddy high mount manifold
greddy external wastgate type r
greddy y intake pipe
hks pod filters
greddy Fuel Rail
hks fuel reg
Sard 700cc injectors
Tomei Sump Baffles
apexi power fc d-jetro
superspark coilpacks
custom rwd sump
4 inch dump
trust stainless 80mm cat back exhaust
cooling pro 600x300x100 intercooler
custom 3'' cooler piping
saber alloy radiator
twin 12 inch thermos
alloy polished overflow bottle
turbosmart e boost 2 (40psi)
turbosmart supersonic bov
whiteline sway bars front and back
whiteline strut brace
rear adjustable camber arms
rear adjustable toe arms
racing logic coilovers
rb25det gearbox
exedy button clutch
exedy lightweight flywheel
custom tailshaft
walbro fuel pump
saber guages oil press, oil temp, water temp and boost mounted in the air con vents
battery relocated to the boot
r34 gtr v spec front seats
retrimmed door cards in suede
smoked tailights
nismo smoked side indicators
blits fibreglass adr approved vent bonnet
vertex front bar
vertex rear bar
vertex side skirts
shaved boot lock
flared rear guards
resprayed in r34 gtr nur gold (millennium jade) with gold flake including engine bay
volk gts gunmetal grey 18x9+27 18x10+23
made 408rwhp on 15psi and 450rwhp on 18psi
serious offers only.
$31000ono
brad 0421511710 or pm
pm for pictures as its not working
https://www.sau.com.au/forums/topic/344357-fs-rb26-powered-s15-2001-rbs15/
Why cant you bring it with you?
Im pretty sure with the rules in WA if you have owned the car for more then year then when you move here you can just go and get WA numberplates for it and rego'd it here. So doesnt need to be inspected etc.
If this was licensed in WA would sell quick over for sure.
thanks for the comments also thinking of putting a standard motor in for anyone that has a lower budget
please dont do this....... keep it how it is... someone will buy it, i wish i had more cash
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
