Item Summary: S13 RB25DET show car heavily modified s13 [smk 13]
Condition: New
Reason for Selling: time to move on
Asking Price: 19,000 ono
Delivery Methods: PickUp
Contact Info: here or 0416589889 or 0433104519
Extra Information:
S13 rb25det nearly finished project
Engine &running gear
lots of chrome
Forged Larry Perkins race pistons
Fully balanced & blue printed crank &rods
Acl race bearings big/mains
Arp rod bolts
Full reconditioned head
Rb26 gtr inlet manifold
1000cc injectors
High mounted gt3540
4" stainless dump pipe into full 3" exhaust
Orc twin plate clutch
Rb25det gear box
6x bosch external coil packs
Rb25 det power fc with commander
R200 mini spooled diff (not shimmed or welded)
Full 5 stud conversion
R32 front 4 spot brakes
1.5L stainless swirl pot
Interior
Brand new carpet
Re covered rear seat upper and lower
Modified safty 21 half cage that has been chrome plated
Recovered hood liner
Full black interior
Stealth sony cd player with column controller
5" monster tacho
Detachable steering wheel
Exterior
Full adrenalin auto styling kit
Front bar is a modified s14 bomax
Side skirts are c-west
Rear bar custom adrenalin
Full custom vented bonnet
Car has been covered in a custom pinkish red pearl
Duel blade alloy drift wing
Personal plates smk 13 (smick 13)
Wheels
Stitch rim
Fronts 18x8 235 35r 18
Rear 18x10 265 35r 18
https://www.sau.com.au/forums/topic/344658-s13-rb25det-show-car/
