Ok, so I've managed to get the old globe out, tweak the locking pin to fit around the HID globe, put the ignitor onto that and attach it to the ballast... but now I'm not 100% sure.
So there was a green and black cable running to the light itself, with what looks like the black one having the end cut off and changed to suit a screw in. So, I'm assuming I need cut that end off and change to suit the pin connector as per the first image. Can someone confirm for me?
Next question, the plugs that attach to the ballast, where do I need to solder these cables into?
I've scoured the net for close up pics of the back of the headlight which I'm sure will answer my question but no luck. Thanks in advance.
https://www.sau.com.au/forums/topic/344670-hid-technical-question/
Oh and give Alistair a call from Autoworx
Contact Details:
Phone: (08) 9409 2445
Fax: (08) 9409 2446
Address: 30 Automotive Dr, WANGARA W.A.
Email: [email protected]
http://www.autoworx.com.au/
He's does compliance on them so would know
quite simple . follow the two coloured wires back to where they were cut :)
the bulb already has power.
Thanks Chris, just to confirm... so solder the green and black to the orange wires of the plug?
That was my initial plan, but the pins on the back of the ignitor psyched me out.
  • 4 months later...
Hi guys!
I finally had a chance to remove my bumper and get the head light units out......... only to find that they cut away the ignitor :(
Good thing out of this little excercise was that the HID fog light kit I have installed only had their connectors disconnected from the balast units, so connected these and whola! they worked! nice :)
I'm going to phone around locally (Perth) and find out if I can source the harness quickly or at least the ignitor piece to fix up the headlights now.
I'd like to do this soon as I am think of selling the V.... yes that's right selling the V! :( I know what you are all thinking, pointless fixing up the HID, but I just feel like doing it out of fun and to say that I finally did it :)
Ok cheers guys!
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
