I was talking to my boss about the electric fans just yesterday, asking him how hard it was to set it up. He reckons it was a piece of piss and he even told me that I could have the brand new fan out the back that he never got round to fitting on his old mazda.
Just gotta make sure that when you set up the electrics, you make them trigger off your A/C switch and also from your adjustable thermometer.
Sumo
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-690303
yeah i think i'm going to get one myself. the clutch fan packed it in so i took it off which means that all i've got left is the little thermo on the front which seems to be doing well so far. gotta drive with one eye on the temp until i fit a thermo tho
if you can fit a thermo to make good use of the factory shroud it should work efficiently with one fan.
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-690346
Two things to look out for:
1. You have to set up a system that forces the air to go thru the radiator. Otherwise, the air simply passes out underneath the car and the engine overheats.
2. You need to re-wire the small fan out front of the A/C radiator. This is a thermo fan, and only comes on when the engine gets too hot. Without cooling air (normally provided by the standard clutch fan), the A/C gas over pressurises, and it sounds like a BOV going off.
IMHO, the power gains (couple of kW) are not worth the headaches.
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-690611
where do you get these thermo fans from. I looked on the davies craig site and a 16 inch is over 300 bux (for all the 16 inch kits). Thats a bit much don't u think, I want to upgrade to clear future piping but does anyone kno of any other good fans that are a little cheaper.
Also couldn't u hook up the wiring so that the fan will only work when the thermo opens. That would be good for those cold morining starts, coz the clutch fan always spins.
rom.
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-691060
I know a fair few of you are sceptical of thermo's, but all the big semi's run an electic clutched Horton fans, and if setup correctly from the start have no problems with them what so ever. I was thinking of getting a shroud off a car with a similair size radiator and modifying it to suit.
Sumo
P.S. Only problem I have is how do they stop the thermo's from overspinning at higher speeds?
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-691529
Ok I have now installed a 14inch daviescraig fan, brought from Burson auto parts, cost me $120 but i get cost from there.
It works great, you can also get a themro switch which you place in the radiator housing and once it is up to the temp you want it to it will kick in, takes a while to adjust but it works nicely.
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-691695
My 16 inch Davies Craig hasn't missed a beat in over 12 months.
Temps are stable, engine responce up a little, and had no problems.
As said before, you need to re-wire the AC fan to come on as soon as you turn the AC on - I've got a thread on this so do a search.
I'm running the thermo switch as well and have found that in winter it pretty much never turns on with normal driving, and only comes on occasisionally when stopped still for 5+ minutes.
Summer it'll come on for 1-2 minutes then stays off for 3-4 minutes.
One thing I found with the Davies Craig kit is that the fuse holder you get with the kit is CRAP... Replace it straight away with a good quality one that can handle heaps of current. Mine melted after about 3 months !!
The 16 inch version draws 19 amps while just spinning, on startup it'll peak upto 30 amps.
The only reason why I ditched my old one clutch fan was cause I thought it was stuffed, and I got the DC 16 kit cheap. I later found out that it wasn't the clutch fan that was stuffed !!!
J
https://www.sau.com.au/forums/topic/34468-thermo-fans/#findComment-691761
  • 7 years later...
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
