markr34gtr Posted February 18, 2004 Share Posted February 18, 2004 i have twin hks 2530 turbos on a gtr with gold looking actuators.... the problemb we are having is boost spikes and holding steady boost.. it can hold about 16psi but no more as the boost jumps all over the place.... but sometimes even it spikes if i leave the boost at one setting.. could my old actuators be getting sad...... if i upgrade to the hks silver 1.0bar actuators can they hold higher boost.. i am running a new blitz id 3 controller in manual mode set to 52 boost ratio and 20 gain.. (16psi).i also mounted the blitz soleniod under the pod filters so the hoses are nice and short for better response.. cheers... Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/ Share on other sites More sharing options...
Sydneykid Posted February 18, 2004 Share Posted February 18, 2004 Hi Mark we always run the wastegate spring rate as close to the boost level as we can. This means the boost controller, whatever type, only has to regulate a small amount. Plus the higher spring rate eliminates any chance of premature wastegate opening. I am not familiar with the Blitz boost controller, so I can't help there. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690587 Share on other sites More sharing options...
Merli Posted February 18, 2004 Share Posted February 18, 2004 Mark, That's a great boost controller you have there, one of the best on the market. Gain doesn't seem to be too high, but have you tried setting it on zero and seeing if that corrects the boost spike? When setting up a boost controller, you should always put gain to zero, and set the solenoid duty until you reach the desired boost level being held at peak, and then slowly turn up the gain to bring up the response at much as possible without spiking (too much)... As SK said, the best method of boost control is buy a wastegate actuator with the correct spring rate to open at your desired boost level, but that eliminates the ability to turn the boost down for wet weather/valet parkers/friends/etc... Good luck! Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690610 Share on other sites More sharing options...
markr34gtr Posted February 18, 2004 Author Share Posted February 18, 2004 thanks. the actuator rods are adjustable. i might give the spring a bit more preload... this might help.. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690641 Share on other sites More sharing options...
markr34gtr Posted February 18, 2004 Author Share Posted February 18, 2004 thanks. the actuator rods are adjustable. i might give the spring a bit more preload... this might help.. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690644 Share on other sites More sharing options...
markr34gtr Posted February 18, 2004 Author Share Posted February 18, 2004 Mark,That's a great boost controller you have there, one of the best on the market. Gain doesn't seem to be too high, but have you tried setting it on zero and seeing if that corrects the boost spike? When setting up a boost controller, you should always put gain to zero, and set the solenoid duty until you reach the desired boost level being held at peak, and then slowly turn up the gain to bring up the response at much as possible without spiking (too much)... As SK said, the best method of boost control is buy a wastegate actuator with the correct spring rate to open at your desired boost level, but that eliminates the ability to turn the boost down for wet weather/valet parkers/friends/etc... Good luck! thanks, i might try to adjust the threaded rods on the actuators a bit to load up the spings a bit more.. thanks guys... Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690648 Share on other sites More sharing options...
meshmesh Posted February 18, 2004 Share Posted February 18, 2004 mark, I've attached a pic of my 2530 with silver actuators.. are these the one you say are rated at 1bar? Apparantley it's written somewhere but buggered if I could find Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-690653 Share on other sites More sharing options...
markr34gtr Posted February 18, 2004 Author Share Posted February 18, 2004 yes the silver ones or 1 bar spring i believe...correct me if i am wrong.. my ones are gold but have the adjustable rod.... i have just adjusted the rod a few turns more to preload the wastegates a bit more... about to try it out after dinner... another mod i have just fitted a 62deg nismo thermostat to help cooling....how helps a bit... cheers.. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691067 Share on other sites More sharing options...
Merli Posted February 18, 2004 Share Posted February 18, 2004 My GT-SS have silver actuators and are adjustable too... Weird. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691085 Share on other sites More sharing options...
jnr32r Posted February 18, 2004 Share Posted February 18, 2004 my 2535 has a gold hks one and std boost is just under 1bar... also have the same boost controller and dont feel any difference between gain settings... Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691366 Share on other sites More sharing options...
jtir Posted February 18, 2004 Share Posted February 18, 2004 silver actuator on the gt-rs has factory setting of 0.9 bar. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691367 Share on other sites More sharing options...
meshmesh Posted February 18, 2004 Share Posted February 18, 2004 i thought the actuator had the setting marked on the unit itself, but I'm buggered if I could find it, just a bunch of serials? anyone know. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691409 Share on other sites More sharing options...
markr34gtr Posted February 18, 2004 Author Share Posted February 18, 2004 i think for high boost i will order the silver hks .9 or 1 bar ones if i want 1.4 bar boost.. with no spikes in the boost curve.. Link to comment https://www.sau.com.au/forums/topic/34492-hks-actuators-on-2530s/#findComment-691501 Share on other sites More sharing options...
