All Cars/Bikes
For Sale? Or Wanted?*
FS
Price/Amount
10000
Open to Swap?
Yes
State
VIC
Short Description for title?
R32 SKYLINE - GTR Mockup
Currently Registered?
Yes
Transmission?
MANUAL
REGO/VIN Number?
Contact Info Other than this Forum?
0430 084 005
Description
hey guys,
up for sale is my Nissan R32 GT-T Skyline with a $2500 custom paint job (black with red/purple pearl) its got the GTR body side skirts, front and rear bar and the wing. its sitting on 18" deep dish wheels with RWC tyres all round.
IT COMES WITH A BRAND NEW CARBON FIBER BONNET AND GTR CARBON FIBER GRILL WHICH WILL BE FITTED WITHIN THE NEXT WEEK OR SO also comes with brand new areocatch lockable carbon fiber bonnet pins which all cost me $2000
modifications:
- 3" turbo back exhaust
- massive front mount cooler
- 6 month old heavy duty clutch
this car has never been boosted or used for any reason. only running 5 psi
-GTR Injectors
-8000k HID headlights
a quick walk around the car
---------- Post added 14-11-10 at 12:37 ----------
Open for swaps
QUICK WALK AROND THE CAR
https://www.sau.com.au/forums/topic/344993-r32-gtr-mockup-10000-or-swaps/
does it still have a defect?? I found this link to the same car with a few changes of number plates and parts....
Tried to do a vicroads check online but it does not work with your number plate in the pictures...
Also how come your selling the car? you have only had it since around October?
http://www.calaistur...ad.php?t=211897
Edited by 180JDM
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
