Hey guys, recently brought an R32 GTS-4 which has a few stage one mods and want to know where abouts to go from here.
Currently has:
R33 Turbo
3 inch turbo back exhaust
FMIC
Bosch 040 fuel pump
Running 10psi
Standard airbox
I was thinking of getting it nistuned next, however should i upgrade injectors or will the stock ones be ok?
Car is daily driven, must be a reliable tune/setup, hoping to get around 180-190rwkws. But more the better provided it's somewhat reliable :)
Cheers.
Edited by Benji82
https://www.sau.com.au/forums/topic/345064-where-to-from-here-performance-mods/
Your stock injectors will be fine for that power level.
Nistune would be the best thing to do next.
Seeing as you have the 4WD model a good clutch should be on the cards too.
Sorry forgot to mention, has exedy heavy duty clutch and aftermarket suspension.
should have had a tune before the turbo swap... so most certainly you need to sort that out.
why? before the turbo swap it was a stocker with an exhaust and a cooler.
nistune would make a nice upgrade. you might find youself maxxing the standard injectors but every car is different
We will see how we go. Yeah I brought the car with the mods already done, so hoping to get the most of whats already there for the time being.
Will go with the nistune and take it from there. Thanks.
Edited by Benji82
All cars benefit from a good tune regardless of stock turbo or not.
Didnt see the part about him recently purchasing, either way ECU is next
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
