Hey guys,
I tried fitting my replica R34 GTR wing, but the sale did not include the screws. The replica appears to have screw holes on which the previous owner used to attach it to the boot lid.
From my observations, the factory spoiler has 2 threaded studs fixed to the spoiler (2 on each end), effectively held on by four nuts to the threaded studs under the boot lid.
Is there something I can buy off the shelf?
https://www.sau.com.au/forums/topic/345068-replica-r34-gtr-wing-screws/
Okay guys. I think Z in the picture is what I need. Any idea's on what it's called? It would be easier if I could identify what sort of screw it is so I can purchase it.
You may be able to, but if they are push cast into the wing (doubt it), or if the hole is brittle the wing mount may be damaged...
If they are screwed in, you can remove by putting 2 nuts onto the stud, tighten the nuts into each other then, undo the first nut you put on with a spanner etc.
This will usually undo the stud.
Good luck!
Alright guys, it appears that standard non-tapping screw with a big washer works fine. I went to a panel beater (Sheen Group in Hoppers Crossing) and asked, he gave me four screws with washers for free. Nice chap that one.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
