DR1FT4 Posted November 23, 2010 Share Posted November 23, 2010 Ok i got a hks T04R set up on my rb26 and its laggy as f**k. full boost by 6500rpm which is just rediculous, so i think the rear housing is a 1.15 just wondering what size i should drop down to and what lag can i expect on that. i really only want 450awhp from it so any suggestions are great, also are any other common housings readily interchangable with the T04R? thanks Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/ Share on other sites More sharing options...
R31Nismoid Posted November 23, 2010 Share Posted November 23, 2010 Sounds about right for an very old tech turbo with a ridiculously big rear housing. You'd need to be around the .82 size to get it to be of any use, even then mate, it's not going to be the best performer for that power goal Ideally for that power mark, a GTX3076 (or a GT35) is what you want. Not an old hat 04R Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5562999 Share on other sites More sharing options...
DR1FT4 Posted November 23, 2010 Author Share Posted November 23, 2010 have you got any suggestions as to what turbo i could swap it out with for a little less lag and about that power mark? preferably with the same flange so i dont have to change the manifold Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5563005 Share on other sites More sharing options...
STATUS Posted November 23, 2010 Share Posted November 23, 2010 i will check what size rear was on the 470-500rwkw 1.5jz we tuned full boost around 4500-4700rpm Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5563008 Share on other sites More sharing options...
DR1FT4 Posted November 23, 2010 Author Share Posted November 23, 2010 that would be much appriciated Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5563011 Share on other sites More sharing options...
Nee-san Posted November 23, 2010 Share Posted November 23, 2010 i will check what size rear was on the 470-500rwkw 1.5jz we tuned full boost around 4500-4700rpm Fuel ? Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5563142 Share on other sites More sharing options...
jangles Posted November 23, 2010 Share Posted November 23, 2010 .82 should easily get your power goal.. or switch to a smaller more responsive turbo as stated Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5563217 Share on other sites More sharing options...
T04GTR Posted November 24, 2010 Share Posted November 24, 2010 .84 twin entry on a ebay manifold had full boost by 4k in a loaded gear, anout 5k in 1st. (t04z) 115 is a rotary sized housing, evan .96 is to big. most turbo shops will have some laying around. p trim turbine . Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5564402 Share on other sites More sharing options...
DR1FT4 Posted November 25, 2010 Author Share Posted November 25, 2010 new one ordered and on its way, thanks guys Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5566085 Share on other sites More sharing options...
jangles Posted November 25, 2010 Share Posted November 25, 2010 what did you go with? Link to comment https://www.sau.com.au/forums/topic/345284-maaaaaad-lag/#findComment-5566874 Share on other sites More sharing options...
