Trying to organise something this close to Chrissy usually fails unless there's looooots of notice. Most people have stuff on.
Maybe try for the first weekend or two of January for a better response.
As for me, I'll be in Temora watching airplanes. :ermm:
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5567502
airplanes, awww why didn't i know about this??? what is on at temora, an air show?
as melly said, we are out of town on the 4th (not at temora)
Yeah they hold airshows 2 or 3 times a month. I got lucky last time I went when they had a P-51 Mustang show up.....the noise that Merlin engine made poops all over any car that's ever been on this planet.
http://www.aviationmuseum.com.au/
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5568018
We can just go to Griffith on a weekend the Temora Airshow is on and you can look :banana: then we keep driving :( Fair??
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5569268
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
