Trying to organise something this close to Chrissy usually fails unless there's looooots of notice. Most people have stuff on.
Maybe try for the first weekend or two of January for a better response.
As for me, I'll be in Temora watching airplanes. :ermm:
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5567502
airplanes, awww why didn't i know about this??? what is on at temora, an air show?
as melly said, we are out of town on the 4th (not at temora)
Yeah they hold airshows 2 or 3 times a month. I got lucky last time I went when they had a P-51 Mustang show up.....the noise that Merlin engine made poops all over any car that's ever been on this planet.
http://www.aviationmuseum.com.au/
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5568018
We can just go to Griffith on a weekend the Temora Airshow is on and you can look :banana: then we keep driving :( Fair??
https://www.sau.com.au/forums/topic/345571-paintballing/#findComment-5569268
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
