Hey guys just installed a 16" Ice thermo fan on my r33 gtst. Everything seems to be fine im not overheating or anything.. Just wanted to know if the fan setup is Push or Pull. I think my thermo is set up for pull as ive just followed the angles on the fins that were on my clutch fan.. though it seems to be pulling through alote of heat. I can feel it from the engine but my temp gage is reading fine right in the middle but then again i havent gone for a long drive.. u guys got any idea on how it should operate? push? or pull?
https://www.sau.com.au/forums/topic/345642-r33-electric-thermofan-push-or-pull/
The manufacturers generally recommend the fan is set up as a PUSH fan, which means mounting in front of the radiator. I realise that is difficult because of all the A/C stuff and IC hanging around out there. So when you mount the fan inside the engine bay (behind the radiator), you set it up as a PULL fan.
And of couse the air is hot because the fan is pulling air over a hot radiator.
BTW, how are you switching the fan on when the engine gets a bit hotter?
Well i hooked it up to an ICE thermo fan switch its the same brand of the fan.. last night i took it for a long run and she over heated and cracked the radiator.. i took a look at some threads on other sites and they said the fan i got is rated at 2500 cfm i dont get why i over heated i took it out for about an hours drive from my house in green valley to silverwater via the western mototway and she was fine... on the way back though it started to have issues whith spike and then dropping temp
Have you got a pilot light to indicate when the fan is operating? Have you set the fan operation so you know when it turns on / off?
The cfm rating of a thermo fan is irrelevant to keeping the engine cool at highway speeds. If a thermo is installed correctly, the only real time the fan should turn on is in stop / start traffic, or if you just let it idle for extened periods of time. If you have the thermo fan working all the time, then you are basically defeating the reason for having a thermo fan, and that is to take load off the engine (you simply transfer the load from the factory fan to the alternator).
When I had a thermo (Davies Craig) I had problems keeping the engine cool - the fan would turn on at highway speeds on slight upward inclines on moderate temp (25C) days. I figured the problem was getting air to actually go through the radiator, so I put the original factory fan back on. Haven't had a problem since.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
