Hey guys just going through our shed and ive turned up a set of 32 gtst calipers 4 pots and rotors so hmmm front brake conversion
questions
1) is there a diff between r32 gtst calipers and r33 gtst callipers?
2) and diff between 33 and 32 rotors my memory is not that good think 32 are like 280mm or something not sure about 33
3)would it still be worth the upgrade using the 32 rotors seems there brand new and sitting in the shed
any help would be good
cheers
Rose
https://www.sau.com.au/forums/topic/345744-quick-brake-question/
1) Yes, R32 GTST callipers are suited to 280mm rotors and R33 GTST are suited to a 296mm rotor. mounting bolts and brake lines are the same, just some cosmetic differences, the 32 ones have fins and 33 ones don't.
2) as above, R32 280mm, R33 296mm.
3) its up to you, stock stagea callipers are only 2 pot fronts compared to the 4 pot 32 ones, but the 32's are a smaller rotor than the stock stagea, i think S1 stagea rotors are 290mm. alot of people will argue that with new rotors and a good set of pad the stagea ones are good enough. personally i'd sell the R32 ones and track down some R32 GTR/R33 GTST ones, they are 4 pot and run the bigger rotor.
just make sure you trail fit before committing to installing any of them, especially check the calliper to rim clearance as the 4 pots will stick out about 20-25mm further towards the rim disk.
Edited by QWK32
hmmmm so can any one confirm the size of s1 stag rotors if they are the same size as 32gtst rotors i will prob chuck these gtst rotors and calipers on at least there 4 pots
cheers
so some searching has not helped found a listing for wgnc34 rb25det rotors as 280mm :D but straight under it a listing for wg(n)c34 rb25det rotors at 290mm :) so any one know what the (N) denotes model wise think i should just go out and take wheel off and measure rotors but its cold and late
n=4wd
  • Thanks 1
Pretty sure S1 and R32 GTST rotors are the same size's, as the slotted rotors im running with my stock S1 stag calipers are made for 32gtst
Yep your right measured up rotors today 280mm so will get a set of slotted rotors and use the r32 4 pots i got sitting here
I can confirm this (a little lol) as I run WGNC34 16" rims for drifting on my R33 GTS-t. Rears fit fine (but sit inside the guards like crazy!) but the fronts foul on the callipers as the wheel's offset is too high. It's probably out by about 2mm and can be fixed with spacers, but I'd sooner recommend new wheels :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
