I have a Cefiro that has sustained some frontal damage, however the engine and gearbox are fine. Except for the clutch fan and water pump.
I am looking to sell it has an entire package which consists of,
Engine
Gearbox
Loom
ECU
Brakes
Suspension
Basically it is a complete front cut with the rear end of the car still attached :D
It is located in south east Queensland. Looking for $1700 for the lot.
https://www.sau.com.au/forums/topic/34606-rb20det-conversion-package/
Front of car is NOT repairable, the drivers side chassis rail is visibly kinked, along with the windscreen pillar, and the roof is bent. I copped a fair hit, but fortunately the impact went through the drivers side, not the engine bay. Damn drink drivers GRR
Sorry i did not realise i had not provided contact details. DUH!!
Located on the Gold coast. contact me on 0402 807 417
Unfortunately i have the vehicle stored on a friends property and will not be able to get pics this weekend. I do however have "normal" pics. I have no scanner so i can't post them to you. Give me a call we will work something out.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
