Hey guys. You're usually really good when it comes to friends in need, and I have a friend who needs a std R34 GTR ECU for his car as he's reverting it to stock after getting an EPA notice :D
The std ECU he sourced is not working properly, the poor guy bought the car with everything known to be modified (2.8L Renik motor - Was a track car in Japan) and restored/stripped everything back and can't get it started. He and his mechanic narrowed it down to the ECU now - He's called a few workshops with no luck, so if anyone has one lying around happy to lend or wanting to sell let me know and I'll pass on the information to him.
Thanks guys,
Steve.
https://www.sau.com.au/forums/topic/346259-r34-gtr-standard-ecu-needed/
NICE signature bud...hehehe....have a look if the 33 gtr ecu is the same or can be used on the 34.....if so...he can BORROW mine... :D...just for epa reasons i want to keep my standard parts....
Thanks Paul - That's what I figured. He first had an issue with the CAS pins which I think were swapped around, and the onboard immobilisers control isn't helping the cause as well but they're pretty sure of the problem. Hopefully another ECU can answer some questions.
BTW Harsh here's the full pic (Think it was in the show n' shine thread?):
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
