  • Replies 42
thing is, the only kunts left playing CS:S tend to be farking good at it, due to playing the same game for the past 5+ years
and they dont want to leave it because theyre shit at everything else, so they play what they know...
What a strange way to generalise people that play a game...
Playing games comes with what skills you use with your brain to be able to think and react in time and CSS is no exception. (Who turns the corner and shoots first) the only difference is CSS still has hacks roaming and about 60% of players use them.
I can play lots of games just fine and usually am put into the whole "elite" section of things. But that's not to say i dont have skills in other games or in life...
That is just stupid.
I thought we said CSS -.- yeah i dont deny that. When Cata comes out tomorrow i wont have a life till i am 85 either hahahaha!
And thus is the life of a true gamer (who works in real estate). But thats the beauty of life i guess.
and we can hurl insults online while maintaining some anonymity
lol so true
I'm keen for some CSS, havent played in ages since my regular GA server died due to the update. My Steam ID is "typevu".
swear i've played and seen ya name i was mega cs:s whore for agesss your pretty good from memory
man im so sick of hearing about css, its the most overrated bs game on the net...
its just 12 year olds pulling the same moves over and over on the same fken map...
bs your just crap.
try like 8+years cs 1.3- 1.5 best cs EVAR
Forums going down just before i left pwned me :D
Im back from Syd - Next week Thurs
I will start thread tonight once i tally the games.
If anyone else wants to jump in - more the merrier, just state what games you have :)
Guest
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
