Amplifier Bar
Guest trikdoutbuketofshit
shit eh, sounds like I should pack some heat lol.
So I should be safe wearing my nike shocks???? I hate wearing my faggy black going out shoes. Only wear em if I absolutly must.
Learn some taste dude, Amps/Capitol has better music than most clubs these days. Not like all this r'n'b and hip hop flith that people call dance music.
p.s. AM bar for me anyday...
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5578570
LOL tramplifier bar. I went there when I was younger, place is just straight heinous now. Wannabees looking for fights, Juvies causing a scene... to sum it all up...
You just described every 'club' or 'bar' in Perth these days. I can't go out these days and not feel like almost every other guy is looking down on everyone else and trying to find a reason to start a fight to win over some broad minded person's approval. Then the broad minded persons are just showing off as much skin as possible, to get in touch with a man's heart's (read: penis) ability to give free drinks. Then they winge when they get cracked on. Simple females: if you don't wanna be cracked on, don't dress like a broad minded person!
/rant.
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5581999
/rant.
What the hell happened last time you went out?
https://www.sau.com.au/forums/topic/346445-amplifier-bar/#findComment-5582466
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
