With wheelspin was quickest way...Anyhting less was bogged down and took to long to get boost. As i said that was my best time for the day. I tried lots of different techniques.
You dont see top fuel drivers spinning their wheels through gears and they get pretty good times.
Have you seen how big and sticky their tyres are? And suspesion set up to go straight. They are race cars, i drive mine around corners occasionally.
Saying that "Yer she was spinning into 4th" may sound like your car is uber powerful etc... but it doesnt help your et's.
Did not say this. Said if i could get power down without wheelspin i may get 12's.
https://www.sau.com.au/forums/topic/3465-fast-rb20s/page/2/#findComment-59832
Originally posted by rev210
set of bfg drag radial TA's are DOT and therefore not cheating, Niz30 with his mph has a low 11 potential with these sort of tyres and a Whiteline KCA349 diff kit (only $104).
I stand corrected.
Can you use these tyres on the road then?
If so, how much are they and what are they like for road use?
https://www.sau.com.au/forums/topic/3465-fast-rb20s/page/2/#findComment-59910
Guest nismogtsx
I have to admit a very bad thing.....
I got completly smashed the other day by a FORD......
It was an old XY falcon with a 351 GT motor and a massive blower hanging out the bonnet, but he was giving me **** and i thought ill go him but it got me by over 4 car lengths in 400 metres.....
It looked like a big wanker mobile, but it had some serious fuel swallowing ability's... LOL
https://www.sau.com.au/forums/topic/3465-fast-rb20s/page/2/#findComment-60739
Yes those old ford do haul arse.
There is one getting around that has wide arse wheels, lowered very slightly with a hornet type bonnet scoop and a nice blue.
It looks and sounds very very tame.
I suspect that he has it supercharged or something as it is to quick for how smooth it idles.
i.e 265 at least on the rear it can light then up no worries from first through second then it starts to get a little hary as the arse end starts to flick around a bit to much. Well when I saw it anyway.
He doesn't stall it up at the lights just guns it as it wheel spins anyway.
When i was making 152rwkw he ate me and spat me out by around 3 car lengths at 100km/h.
https://www.sau.com.au/forums/topic/3465-fast-rb20s/page/2/#findComment-61053
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
