Just had a change of plans im sticking with my 25/30 kit thats already on the car.
Turbonetics is one of the best turbos out of the states and are very popular,Turbo has a no questions asked 1 year warrenty as of today as it turned up today warrenty period starts today.
This turbo is somewhere between a t51r spl and a to4z powerwise but i have been told this turbo starts to make boost around the 3800 to 4200 rpm depending on strenth of motor and cams so its very streetable but will produce more power then a t04z.
"new" GTK850 850hp turbo oil and water cooled comp inlet 4.0"/2.5" turbine housing t4 0.081ar 4bolt These turbos retail for about 2200.00 USD then you have to pay for frieght.
These really are a awsome sounding and looking turbo,Same turbo was used in FNF tokyo drift in the mustang if you want to know what they sound like they are very diffrent.
"new" Turbosmart progate 45 mm chrome
Hks rb26 t4 manifold to suit said turbo Manifold is in perfect order has seen about 1000kms of use was purchased bran new and is in excelent condition,These manifolds retail around the 2.2k mark from hks and second hand jps sells them for 1800 bucks aud they are not very common to find.
Greddy poilished twin airflow meter inlet pipe
As you can see i dont buy cheap stuff i never short a thing all this gear is in perfect working order well it should be its new.Receipts will be posted with gear.
I really would rather sell as a kit then split it up but if people are taking all the parts between them then i guess id split.No tyre kickers please only bid or pm me if your really intrested in buying the items.
Basicaly all you need is a dump pipe and your off and running :D
ITs a shame id love to have went forward with this kit took me months to get this kit together.
Price is firm
$4300.00
Pm me or text/call 0427284275
Edited by Gtir-keiron
Bump this stuff needs a new home!
Be diffrent i say.
The turbo is Turbonetics top end line of turbos.These guys did the surge porting befor any one else and there turbos are regarded as some of the best in the world.
  • 4 weeks later...
hey mate would you be intrested in swaping your manifold for a brand new garrett t04z in the box maybe it might be easyer for you to sell but u would have to give me couple hundread on top
no thx mate just sold a turbo.
wastegate new
manifold
twin pipe greddy
also have a 90 mm throttle body nissan for sale in tip top condition for 250 ono
Bump all still for sale throw me some offers.
  • 4 weeks later...
Sorry been busy the greeddy piple and wastegate still for sale
Also have a 90 mm throttle body a nissan one in perfect woprking order very clean
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
