hi guys, its my 1st post so sorry if this looks a lil rough around the edges...
Over the weekend i just became the proud owner of a very straight and tidy manual '95 R33 gts25t series II SEDAN with next to no mods apart from an apexi filter, 3" cat back zorst, and coilovers on 18's. bought it for 10G's which i know is a bit pricey i spoze but the fact that it has only done a tad over 60,000 on the clock made me justfiy the spend...
but wihout digressing too much, i noticed only today that in the drivers area are these 2 "LEG PAD thingys" that the outside of my knees are always resting on...1 is on the drivers door located just above the speaker, and the other is bolted to the center console at about the same height as the head-deck...
i have seen a few R33's (mainly coupes) but none of them have had these... so i guess my question is-what are they, and what is their use? im not a small guy by any measure so theyre sorta annoying as i feel a bit squashed-ive pulled one of them off to see if they were stuck there by someone other than the factory but sure enough, when i looked @ the back they had nissan stamped all over them. i rang the guy i bought it off and he said he had no idea but he did state that when he brought it over from japan, the car cost him a little extra compared to other R33's because apparently it had nearly every extra factory mod that was available for this model...from ABS brakes to a FLARE GUN (no bull-it sits under the glove box still)-maybe those were just an added accessory?-dunno-thoughts anyone?
ill post some pics ASAP as im @ work at the moment and will get around to it the moment i get home...
cheers peeps...
PS: looking for West Aussie skyline sedan owners to hook up with, as everywhere i look so far is 2door 2dr 2d......-cheers.
https://www.sau.com.au/forums/topic/346737-r33-drivers-side-leg-pad-thingys/
It's not a flare gun, it's just a road flare, pretty sure it's a legal requirement to carry one in Japan.
Not sure about Australia, but when they're imported into the UK, Customs are supposed to remove them when they inspect the car.
No idea about the leg pad thingies. I'd imagine they're just to rest your knee on, but were designed for tiny Japanese salaryman rather than a hulking great Australian.
The leg pads are a factory option, they have been around since the R32 and are available for all skyline models from there on in and I believe stageas as well.
I have them in my R33 GTR too... I didn't likethgem at first but got used to them... :)
as you can see ive got the left leg one off no problem but i cant see any screw holes for the right leg, have you attempted taking this one off yourself?-it looks like it might be stuck there with just an adhesive so im not sure if i want to just rip it off fearing it might take some of the panel with it-i cant see myself getting used to it any time soon so would like to get it off...im hoping it has reverse screws that i can see if i take the whole door panel off otherwise-RIIIIIPPPPPP!!!
  • 1 month later...
Ha ha. You learn something new everyday!!
I've got an R33 4 door with those clips under the dash. Thought it must be for a fire ext or torch. Flares??
Far out ! That's cool. How much to buy one??
Never seen those pad dealies either. Crazy Little People.:ninja:
  • 4 months later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
