Item: 2001 R34 GT-R V-Spec II
Price and Payment Conditions: $100k ono
RWC: Negotiable
Engine
Godzilla Motorsport built RB26
Head porting/polishing
Godzilla Motorsport custom dry sump with Petersen 4 stage pump and Morosso 2 gallon reservoir (boot mounted)
Braided dry sump lines
HKS pod filters
Rising Garage titanium twin turbo piping kit
Rising Garage titanium air filter piping kit
Garrett 2860R-5 turbos
HKS 1 bar actuators
HKS split dump pipes
HKS Tuned length front pipe
Trust PE Ti-R 90mm titanium exhaust
Trust Spec-R HG Type 29 700x300x115 intercooler
Trust Type-R blow off valve
Hi Octane Racing catch can
Custom fireproof engine loom
Splitfire coilpacks
ATI 1000hp super damper balancer
PWR cross flow 48mm radiator
PWR oil cooler
Garage Defend carbon fibre radiator cooling panel
Fuel system
Injector Dynamics 1000cc injectors
Bosch 040 fuel pump x 2 (external)
Sard 276L/hr fuel pump (in tank)
2L swirl pot
MagnaFuel fuel regulator with pressure gauge
Hypertune billet twin entry fuel rail
Teflon coated braided fuel lines
Driveline
NPC twin plate clutch (Nick’s Performance Clutches)
OS Giken push/pull converter
Footwork
Advan RG 18x9.5 +12 wheels with Advan Neova AD07 tyres (street) OR
WedsSport TC105N 18x10.5 +12 wheels with Bridgestone RE55S tyres (circuit)
Tein Super Street coilovers
Project Mu 6 piston racing calliper (billet) with 355mm rotors (front)
Project Mu 4 piston 4 pad racing calliper (billet) with 345mm rotors (rear)
Project Mu H16-03 brake pads
Project Mu braided brake lines
Dot 5.1 brake fluid
Cusco master cylinder stopper
Cusco 24mm front and 28mm rear sway bars
Ikeya Formula front tension rods
Ikeya Formula front upper camber arms
Ikeya Formula front lower arms
Ikeya Formula rear upper camber arms
Ikeya Formula rear traction rods
Ikeya Formula rear lower arms
Cusco drag rods (HICAS lock)
Interior
Vi-Pec V88 ECU
HKS Type 2 turbo timer
Nismo 320km/h dash
Nismo titanium gear knob
Tein EDFC
Willans 4 point racing harness
Exterior
JUN wing stands
Carbon fibre Nismo style vented bonnet (oem V-Spec II carbon bonnet included in sale)
F1 Car Shop carbon fibre front lip/diffuser
Pics here.
Contact via PM.
https://www.sau.com.au/forums/topic/346772-2001-r34-gt-r-v-spec-2/
Hey Willo,
Dont listen to the wankers on here, let them find out what is cost to build a car like yours.... 58K is no where near enough and considering just the basic car is a VSPEC II you cant even buy this car in Japan for that... People are stupid for dropping the price on these cars..
Hang in there mate, don't give the car away to some tool....
Cheers and a free bump for a good car that is worth the money...
I didnt say his car was only worth 58k. It was just a offer.
If your not interested in buying the car skylinesky then u shouldnt post useless stuff.
He did say make an offer last chance.
A cars true value is what someone would pay for it...
to the owner sorry if that offer offended u in anyway goodluck with your sale.
Edited by Dumpe
Outstanding car.
Be at the front of the pack at track days or cruising the streets in what has to be one of the most complete street R34 GTR's in the country!
Love this car.
Good Luck Willo.
Mick
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
