Over the last few weeks gradually getting worse my R34 GTT has had an issue where I'll be slowly accelerating/cruising along and the car will hesitate for a second. It feels like when the TCS system kicks in and cuts the power but for a shorter time.
At first I was thinking it could be the CAS or something like that but last night whilst driving (with TCS turned OFF) it did it a few times and then the SLIP light came on and stayed on until I turned the car off & on again. I'm wondering if the TCS is for some reason malfunctioning.
(The car had splitfires installed approx 50,000km's ago as well as new platinum plugs)
Any ideas or similar situations?
Edited by so_tred
https://www.sau.com.au/forums/topic/347290-r34-gtt-hesitation-while-cruising/
Sorry for hijacking - this could help u if its not TCS related -
I had that infamous flat spot between 4700-5400 rpms, the car would also hesitate for a sec in fifth gear around 3rps when booting it, although my TCS doesnt work at all - no light on dash at all.
Changed to 0.8mm gapped NGK copper plugs, left my standard coils in. No change to above problem.
Then yesterday after reading a few bits on SAU, I reset my ECU - take off the battery terminals, stab the brake pedal a few times (brake light on/off) to drain off all the charge, then re-connect and go for a drive.
I'm just amazed to say after the ECU reset - the flatspot is almost completely GONE, not only that, the car feels so fresh, crisp and very quick to rev and GO!!
Took it to a workshop yesterday who pulled the error code for the AFM.
It was cleaned etc, drove it this morning and I didn't really feel the hesitation but the SLIP light once again came on.
Is it a symptom of a dying AFM? It just seems like two very different systems?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
