1998 Subaru WRX Club Spec Evo 2 INTERESTED IN SWAPS ! ! !
Modifications:
Forged Oversize Pistons.
Forged Rods.
Arp Head Studs.
Steel Head Gaskets.
ACL Race Bearings.
Apexi Turbo With P20 Housing.
Process West TMIC Kit.
TURBOSMART Super Sonic BOV.
Side Feed Billet Fuel Rails.
X-Force Dump Pipe.
JASMA Canon Exhaust.
Microtech LT10 Computer.
E-Boost Street Boost Controller.
STI 4.44 Ratio Gearbox.
EXTREME Extra Heavy Duty Clutch.
EXTREME Lightened Flywheel.
King Springs.
STI Bonnet Scoop.
18inch ANZ Velvet Wheels Powder Coated With New Tyres All Round.
JVC Double Din DVD Unit.
Kicker Cross Over Speakers Front&Rear.
Kicker 4Channel Amp.
Bap Points: Rear Bar Needs Atidy Up.
Approx: 3000kms Since Rebuild.
Car is in run in tune atm. Making 150KW at all 4 wheels on 8pound boost. Car is now run in ready to be tuned after injectors upgraded.
Contact: Sel 0432336944, txt me your offers.
https://www.sau.com.au/forums/topic/347347-1998-wrx-club-spec-evo-2/
yea man it does. and then wen it comes time to let go nit many people realise!!! id be able to put maybe 2k ontop of mine but thatd be it. :) basically if i dont sort out a sale in the next week or two its gunna be parted out :(
Good luck with your sale mate! :)
over the water in tassie mate :) im pretty keen for a change
its a perfect platform for a pretty nuts car really got all the bits the tuneability of the vipec is incredible.
my 1st car was an R32 so i basically know the car in and out, how could we view each others car in a cheap way lol ?
thats the only frustrating thing now ahah
mine has one one lil issue that must be said. it has an issue with blowing a tiny bit of oil after decel so have narrowed it down tto valve stem seals. ( i just cant be bothered mucking round with it nemore :( )
so car wouldbe as is.
im willing to maybe go upto 2500 because of this issue..
yea man im an honest guy been screwed over today actually in a sale. hence the price drop. ha umm i could make a video and email or something? save flying? but in saying that flights a very cheap atm
yeah i got srewed when i bought this car, stock as a rock and the head gaskets went on me -_- , well what do you want too se of my car, any specific pictures, videos? i'd like to see more bigger and detailed pics of you car engine bay and interios, maybe a video of how it sounds ?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
