my 32 gtst has a t3 turbo, hks low mount manifold, hks gate and has been de-boosted because of it running so lean. I need to do something about the stock ecu and injectors if i want it to see past 240 hp which im on now at 8 psi. ive been told many different things about wolf, stinga and nistune which are what im lookin at.... is it really worth saving for the apexi?
Who is tuning the car?
Go with whatever system they are most comfortable with. As for injectors, anything around 500cc will be sufficient. I would recommend Siemens injectors
This shit has been covered SO MANY TIMES
  • Like 1
C - Red do good work... if you are going to C - Red they wont do Nistune I dont think but ask them what they think is best if you want Jeff to tune it
They have done all the work on my Rb22 = top job
can use 440cc GTR injectors with resistor pack is a common thing too
  • Like 1
called C-red today they said they want to put a haltech inside my ecus casing and ill prolly go with sard 550cc injectors tuned for 2200
Ring Hyperdrive or Allstar Garage and go with NIStune and GTR injectors for probably 1/2 of the price of the Haltech and Sards.
Edited by bubba
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
