hey guys up until a few months ago i owned an n14 SSS pulsar, it had coilovers, sway and strut bars, an SR20de making about 110kw @ the wheels and a stripped interior as my daily. My girlfriend got sick of us having to take her car every time we went out and told me to buy something safer and more practical to put our son it. so i went and picked up an r33 Gts-t. Apparently to her this is not a practical car with a kid, I sat her down and explained to her as nice as I could "too bad car stays" lol. Over the past months i have been spending a bit of time and cash on the 33 so i thought i would make a build thread so I could keep track of what is going on with the car.
this is how it looked the day i picked it up
on the way home I stopped at a mates place that some how picked up the sound of an exhaust leek, I could not hear it at all lol. We had a look around and discovered a few broken exhaust studs. Next day go straight into it and ripped everything off to start replacing the studs (and broke a few more)
and putting it all back together.
Next thing on the list was a service. Not owning a car like this before I wasn`t too sure what to get hope I got what i should of lol. Hpr15 oil, Greddy oil filter, NGK copper plugs ( i don`t like irridiums), Nulon Long Life coolant along with engine and coolant flush.
After all of this i was feeling kinda happy with the car and cruised around for a bit only to get Defected on my way home one night. Not to worry some dodgy moves and it passed. It was at this point i thought the Hektick Dose was crap and opted to run the stock BOV and went about trying to make it a little more un-noticeable and painted the cooler black.
next pay day i went a bit crazy lol brought a HKS pod (im fabbing up a box for it at the moment), Cusco rear strut bar, Juran front strut bar, Greedy breather tank, Turbosmart boost controller, Suede wheel, a fuel pressure reg and a walbro pump.
Pic of Front strut bar and breather tank
Rear strut bar
Steering wheel, shift light and boost gauge
That`s about it for now :D I hope on getting out in the garage and getting some work done tomorrow, if I do ill update with what I have done.
https://www.sau.com.au/forums/topic/347847-r33-daily-build/
  • 5 weeks later...
I haven`t put anything up here for a while but not much has really changed my interior plastics from my gear stick surround to my dash surround have started to go all crap and the paint on them is pealing and really lets the inside down. I tried to sand it down and paint it black but you could tell it wasn`t original so I have scraped that idea and started to look for immaculate ones for sale witch I have not been able to find so at the moment I`m not to sure on what to do, weather I keep on looking or carbon wrap the old ones I have Im just worried with the carbon wrap the inside might start to look like an autosalon car. I also finally put the HKS pod on but have not made a box yet im not to sure what material to use and how i should actual design it. Last week was the worst week and most expensive week that i have had with this car so far I went to get some new tyres Monday 245/45 R17 for the rear and 235/45 R17 on the front. The next day I went for a drive and destroyed my clutch it would not dis engage so I towed it to my mates house Wednesday morning we pulled the box out and the clutch plate was fused to the pressure plate and the fly wheel was marked relay bad. I went and got a PBR/RPM 5 puck brass button clutch and also got the fly wheel machined as well. Tuesday arvo we started to put it all back in and spent 4 hours trying to get the box back in but it would not go we put it down to the shit plastic clutch alignment tool and gave up for the day, the next day my mate went into work and made me a new tool exactly the same as the input shaft we used that and bingo box slid in. On thursday I went down to flemington to pick up some parts as I got there my clutch pedal fell to the ground. We towed it back to my mates house and found out the little pivot ball that the clutch fork pivots on broke so box out again put a new one in and its sill good and all fixed i think!
Car up and box being pulled out
New clutch that we put in
While the clutch was getting put in i put that tar shit on my top pipe after reading about it in the DIY section on this forum. encase anyone is interested we used a Jaycar temp sensor and display we put the sensor in the pipe and it showed 8.5 deg hotter with the tar on the pipe!
And just random pic of the car clean before new tyres went on
Ill try to keep updating as i go
https://www.sau.com.au/forums/topic/347847-r33-daily-build/#findComment-5627694
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
