I bought a used blitz BOV and pipe for my skyline ECR33 but im a little unsure about the install.
1, There are 2 tubes for vacume hose, one on the metal pipe and 1 on the top of the BOV. Where exactly do I connect them to?
2, Do i leave the standard BOV on or do someting with it?
3, Might i have issues stalling? what do i adjust if I do?
also, anyone see any good pics of an install? im still searching the net
thanks, I hope to do this on sunday, so any help is a big help.
https://www.sau.com.au/forums/topic/347850-how-to-install-bov-on-ecr33/
1. Look at your factory BOV. You will see a vacuum hose running from the plenum to the top of the BOV. The Blitz one is the same. No idea what you mean about the second source? Got a pic?
2. You obviously remove your factory BOV and put the Blitz BOV in it's place.
3. Yes you will most likely have stalling issues, can't really do much about that on the stock ECU/AFM setup.
  • Like 1
Phil, the Blitz setup comes on its own pipe (the hot pipe from memory) and yeah I think they have 2 nipples like the stock toyota BOV's on my 1jz a single hose runs from the plenum then splits into two at the Bov (something to do with keeping it open at low throttle, but I doubt that will apply to the atmo Blitz unit.
As for the stock bov, you will need a blocking plate.
yeah thats them, And the "2nd Nipple" looks like it could be the one on the pipe.
That would be for the turbo wastegate actuator.
The nipple on the BOV goes to the intake plenum, just find the stock BOV hose and use that.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
