C34 Laurel Rb25det S2 40000 kms on engine apparently done 7-10,000 since
comes with loom/ecu complete engine only missing turbo.
can have radiator aswell...
$2500ono
RB25 box with short shifter
comes with x member also.
$1400ono
$3500ono package deal
Brand new Excedy Cushion Button clutch Kit.
With Fresh machine Flywheel.
$450
Brand new KKR 430 Equivalent turbo -
good for 250+rwkws
comes with Braided Coolant Lines Earls fittings.
Custom Dump Pipe with 02 sensor.
$700 ono
BRAND NEW Cooling Pro Cooler kit
Suite RB20/25.
$300 ono
RSR front pipe / stainless cat back NEW>
$300 ono
Nismo Adj Fuel Pressure Regulator $80
2 way Mechanical LSD - Nismo GT PRO
5 Bolt. 4.3 ratio.
$750
12 Point Adjustable Coilovers
suite s13 also..
unsure on fronts but no leaks or knocks.
Rears are kei office in good nick.
$650 set or 350 each pair.
Cusco Rear toe arms
$150
Jap Adj Castor Rods
$120
GTR Rear Swaybar links d bushes...
$150
Thick Front Sway Bar
suite s13 etc..
with links and d bushes.
$150
17 inch AVS Model 6 Rims
Pair of 17 x 8 +30 with tread.
$350 ono
Apexi SAFC
with stand. loom in good nick also.
$150
Apexi Multi Checker
with loom and control box.
$150
Sparco Fixed back
With rail to suit s13/r32/a31.
$350 ono
Momo Steering Wheel
with boss kit suite a31/s13 etc..
$120
R33 GTST Brakes and s14 Hubs & LCA Front
R33 GTST Rear brakes and five stud hubs
Braided Brake lines front and Rear.
Good pads.red stuff fronts..
Hand brake and Lines Encluded.
$850
8 Point Roll Cage
Suit sunroof.
$450
Front and Rear Strut Braces
$100 each.
FET TT
$20
Carbon T wing bit Damaged.
all mounts etc..
$400
NON rolling shell
SUNROOF MODEL.
encludes the following:
Rear Subframe and all stock arms.
Complete Wonder Kit. Front Bar/Rear Bar/ Side Skirts.
Wonder Vented Bonnet
Has dash and most interior bits.
body loom all stil there.
has all reo bars.
wired to run rb25det
fuel pump cradle.
can be complied if u be bothered but just track only.
Needs engine x member/rack/ hubs and struts to roll.
$2000 ono
$3000 with 5 stud and a31 cross member..
PM ME EMAIL FOR PICTURES.
All Parts Located Wingfield S.A
can be Inspected anytime just let me know.
will post at ur expense or meet to make it easier if u from down south..
cheers ben
0432580754.
https://www.sau.com.au/forums/topic/348012-stripping-rb25-cefiro/
  • 3 weeks later...
  • 2 months later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
