Hey y'all new south walesers,
I am flying in to Sydney early friday morning, and need to get from the airport to Manly where I am staying. Not knowing a flying feck about the layout and transport systems in Sydney, I was wondering if you guys could help. Is there a train? Bus? I was thinking of getting to the city somehow then catching the ferry over? How far is it from the airport to the city (taxi-wise)? Cheers!
https://www.sau.com.au/forums/topic/34806-sydney-help/
Not from that area of Sydney but a combination of Train + Bus or Train + Ferry should be pretty easy.
www.cityrail.info
www.sydneyferries.info
www.sydneybuses.info
Edit: Should get away with it for about $20.
https://www.sau.com.au/forums/topic/34806-sydney-help/#findComment-696165
haha yeh a couple of ferry's have crashed into the quay over the last few weeks
B-Man.. I'd go the ferry just to enjoy the cruise across the harbour and the views.... I did the trip yesterday from circular quay to manly and back and it was fantastic.. I want a boat now... hahaha
https://www.sau.com.au/forums/topic/34806-sydney-help/#findComment-696296
Agree Tosh - I do it every day - I'm used to the view - although I don't get bored of it, I am often running late for work and need to catch up on the time ;) ha ha ha ha ;)
https://www.sau.com.au/forums/topic/34806-sydney-help/#findComment-696302
