  • Replies 42
gave him a whisker start just to see if he was dinkum, and he was.
A bit of extra boost does make a difference, even on an auto and new Iridiums have gotten rid of the missing, related to the upped boost. Wasn't a lot in it but the main thing is, he got done. Would have been good to have seen the result if some of the other guys' "lines" had tackled him.
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66067
Thanx Chris,
Yeah I got a dose of my daughters driving on Saturday when we hired a motorised golf buggy at Hillview. She wanted to drive the buggy and it kind of gave me a fore-warning of what could happen when she gets her license and begs me to let her drive the "line". She nearly killed the lot of us.
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66078
My daughter is competing on Sundays MC day.
I was thinking of letting her use the Skyline but that would defeat the purpose somewhat as I want her to learn how to handle her own car
Joe
Trip was great
Hid the keys with Lumpy
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66157
Rob
Yes it's in but not working yet.
There has been a hitch with the interface between the unit and the R34's ignition timing system. We are waiting for an answer from Japan so hopefully it will be a goer soon.
Unfortunately the S-AFC had to be removed so it's lost a lot of power temporarily.
Hopefully it'll be OK for the MC day but obviously will mean slower times:(
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66396
Originally posted by Pva_Glue
spectators report to me on arrival and pay be $5.00 per head...:uh-huh:
cheers
Joe:D
Nice try Joe but no, spectators are free and encouraged to add moral support and help with timing and writing on scoreboard.
As the venue is behind the gokarts on wattle av in pinjar ( wanneroo ) , then I think the cott is a bit far away Boostzor.
Ken
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66827
Ken
but Kens place isn't
https://www.sau.com.au/forums/topic/3486-info/page/2/#findComment-66837
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
