I did this mod a few months ago and managed to snap a few shots of the process.
This is for those who want maximum simplicity and low costs involved in a small upgrade.
1-- Remove the front left wheel of your car.
2-- Take off the inner guard black plastic lining. All the bolts holding it in should be plastic and quite easy to just pull out.
3-- Undo all the bolts holding up the R33 SMIC, and also make sure you loosen up the clamp in the engine bay just under the air filter (shown in the 2nd picture). You may need to temporarily remove your airbox (if you have one) to get to this clamp. I had a pod filter so there was a fair bit of space for me to use.
4-- Once the R33 SMIC is removed, install the R34 SMIC into the exact same locations as for the original intercooler.
5-- Reconnect back the inner guard black plastic lining. You will notice that as the R34 SMIC is taller than the R33 SMIC the guard will stick out a bit, or may not bolt back on exactly the same as before.
For me I bolted it all back (with a bit of gusto) and let the guard hang out a bit as a make-shift scoop for the SMIC. Nothing has flown off yet so it seems to be doing the trick and feeding nicely.
DONE!
Probably the easiest mod you will ever do as a beginner - I hope this basic tutorial will be useful to people
After the mod on-boost kick was harder (this may be a mental thing though :))
https://www.sau.com.au/forums/topic/348789-r34-smic-install-on-r33-s2-easy-mod/
Yeah thats the sort of thing im doing. Just bought mine, it has cat back exhaust and pod already, but need a dump and highflow cat. For now i have just done the solenoid mod, but getting a turbotech manual controller to run 10 psi.
Its running well as is, so i cant wait to finish it. Do you think the 34 smic would handle a highflowed standard turbo?
Edited by cannabiscorpse
did you buy it off here? looks like the one i sold to a guy on here about 3 months ago... sprayed silver and all lol!
They imo are only good up to 170rwkws, anything more than that and they suffer major heat soak, but better than a 33 one.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
