Baffled Oil Catch Can
Used 60K in Ohms and got these numbers: 1.45 Ω 1.38 Ω 1.47 Ω 1.43 Ω 1.56 Ω 1.45 Ω I haven't been able to find what the correct range is though so they are within spec /:
For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
By ChriscoDom · Posted
Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
